RV Generator Won’t Start? Step-by-Step Troubleshooting Guide to Get It Running Again
Table of Contents
There’s nothing more frustrating than getting ready for your RV trip—only to find that your RV generator won’t start. Whether you’re parked at home, in storage, or out at a campsite, a non-starting generator can bring your travel plans to a halt. The good news? Most RV generator problems can be diagnosed and even fixed with a few simple checks.
In this guide, you’ll learn the most common reasons why an RV generator won’t start, step-by-step troubleshooting tips, and how to know when it’s time to call in a professional. From dead batteries to clogged filters and fuel issues, we’ll help you get to the bottom of the problem—so you can get back to enjoying life on the road.
If you’ve already gone through the basics and your generator still won’t start, don’t worry—mobile RV generator repair services are available to help, including convenient options that come directly to your location.
Common Reasons Why Your RV Generator Won’t Start
When your RV generator won’t start, it can be due to a number of underlying issues. Understanding these common reasons can help you pinpoint the problem quickly. Here are several factors you should consider:
1. Dead or Weak Battery:
A weak or discharged battery is one of the most common causes. Your generator relies on sufficient battery power to kick-start the process. If your battery lacks charge or suffers from poor connections, your generator may not start.
2. Low Oil or Fuel Levels:
Low oil or fuel is another frequent culprit. Many generators have a low oil shutdown feature that prevents operation to protect the engine. Check your oil dipstick and fuel gauge regularly to ensure your generator has the proper levels to start and run efficiently. Always check your fuel and check the oil level before each trip.
3. Clogged Air Filter:
A dirty or clogged air filter restricts airflow, which is essential for proper combustion in your generator. Regular maintenance of your air filter not only helps your generator start but also improves overall performance and efficiency.
4. Tripped Breaker or Blown Fuse:
Electrical issues, like a tripped breaker or blown fuse, may interrupt the starting sequence. Inspect the circuit breakers and fuses to ensure they’re properly reset and functioning as they should.
5. Contaminated or Old Fuel:
Old fuel can cause blockages and reduce performance. Stale fuel breaks down over time and may lead to deposits in the fuel system that hinder ignition. Ensure you’re using fresh fuel and consider using a fuel stabilizer for long-term storage.
6. Faulty Starter Motor or Solenoid:
If your starter motor or solenoid fails, your generator may click without actually starting. These components are critical for turning over the engine and require proper function to operate smoothly.
7. Electrical Connection Issues:
Corroded or loose wiring can disrupt the signals needed to start your generator. Regularly inspect and clean electrical connections to maintain a reliable start.
8. Error Codes or Faulty Sensors:
Modern generators often display error codes or use sensors to detect issues. If you see blinking lights or specific error codes, consult your owner’s manual or use diagnostic tools to determine the exact problem.
Each of these issues can contribute to RV generator problems, and addressing them early through your troubleshooting steps can save you time and prevent further damage. Next, we’ll dive into a step-by-step troubleshooting checklist that will guide you through diagnosing and resolving these issues effectively.
Step-by-Step Troubleshooting Checklist
If your RV generator won’t start, don’t panic—many issues can be resolved with a few basic checks. Use this step-by-step troubleshooting checklist to diagnose the most common generator problems before calling in a professional.
Step 1: Check the Battery
Start with the most common issue—your battery. Make sure:
The battery is fully charged (12.6V or higher for a 12V battery)
Terminals are clean and tightly connected
There’s no visible corrosion or damage
Pro Tip: Try jump-starting your generator using your RV’s chassis battery if the house battery is low.
Step 2: Inspect Oil and Fuel Levels
Many generators have built-in safety shutoffs that prevent starting if the oil level is low. Also, check:
Fuel level in the tank
Fuel shutoff valve (ensure it’s open)
For diesel generators, confirm there’s no air in the fuel line
Pro Tip: Check the fuel and oil levels regularly—this simple step is one of the easiest ways to prevent an RV generator issue.
Step 3: Examine the Air Filter
A clogged air filter can choke the generator. Remove the filter and:
Check for dirt, debris, or pests
Clean or replace if needed (follow your manufacturer’s guidelines)
Pro Tip: Hold the filter up to light—if you can’t see through it, it’s time to change it.
Step 4: Reset the Circuit Breaker or Replace Fuses
If your generator clicks but doesn’t crank—or if there’s no power output—it might be an electrical fault.
Check the onboard breaker and reset if tripped
Inspect inline fuses and replace any that are blown
Pro Tip: Label your breakers and fuses for quicker access in the future.
Step 5: Assess the Fuel Condition
Gasoline older than 30–60 days can break down and clog fuel lines or the carburetor.
Drain old fuel and refill with fresh gasoline
Add a fuel stabilizer if the generator sits unused for extended periods
Pro Tip: If your generator starts briefly then shuts off, it’s likely a fuel delivery issue.
Step 6: Look for Fault Codes or Blinking Lights
If your RV generator is newer (like a Cummins Onan model), it may flash diagnostic codes.
Count the blinks and match them to the error list in your manual
Common codes relate to low oil, overheating, or over-cranking
Pro Tip: Keep a copy of your generator’s fault code chart in your RV tool kit.
Step 7: Test Manual Start Mode
Some generators allow manual starts. This helps bypass automatic systems and test starter health.
Try starting from the generator itself instead of the dashboard switch
If it starts manually but not remotely, the issue may be with wiring or the control board
By following this checklist, you can often identify the root cause of why your RV generator won’t start. If you’ve completed all the steps and your generator still refuses to turn over or run, it might be time to bring in a certified technician. We’ll cover that next.
What If It Still Won’t Start? When to Call a Technician
If you’ve worked through the entire troubleshooting checklist and your RV generator still won’t start, you’re likely dealing with a deeper mechanical or electrical issue that requires professional attention. Continuing to crank or test components blindly could make the problem worse—or even cause permanent damage.
Here are signs it’s time to bring in a technician:
You’ve verified the battery, fuel, oil, air filter, and fuses, and everything checks out
The generator clicks but won’t turn over
It starts and shuts off immediately, even with clean fuel
You see blinking fault codes or warning lights you don’t recognize
You’ve attempted a manual start, but the generator still won’t run
There’s a burning smell, odd noise, or visible damage to wiring or components
Get Help On-Site with Good Sam RV ProCare
When your RV generator fails and you’re stuck at home, in storage, or out at a campsite, towing it to a service center can be expensive and inconvenient. That’s where Good Sam RV ProCare comes in.
Good Sam RV ProCare offers mobile RV generator repair, bringing certified, RVDA-approved technicians directly to your location. With their remote video diagnostics, they can assess the issue in advance, order any needed parts, and complete most repairs in a single visit—saving you time, stress, and another trip to the shop.
Whether it’s a faulty starter, bad wiring, or a deeper internal issue, you can count on timely, reliable service that keeps your RV road-ready.
Preventive Maintenance Tips to Avoid Future Generator Trouble
Preventing generator problems is far easier—and less stressful—than dealing with one that won’t start when you need it most. With consistent care, your RV generator can run reliably for years and power your travels without interruption. Here are some essential preventive maintenance tips to keep your system in top shape:
Run Your Generator Regularly
Letting your generator sit idle for months can cause fuel to degrade, seals to dry out, and moisture to build up inside. Make it a habit to:
- Run your generator for 30 minutes every 3–4 weeks
 - Turn on a few appliances to place it under load during the run
Use Fresh, Stabilized Fuel
Old gasoline is one of the top reasons RV generators won’t start after storage.
Add a fuel stabilizer if your RV will sit for more than a few weeks
Drain old fuel before long-term storage when possible
Always refill with fresh fuel before a major trip
Check Oil and Filters on Schedule
Low oil or clogged filters can trigger automatic shutdowns. Stay ahead of the curve by:
- Checking oil levels before every trip or every 8 hours of use
- Changing oil and oil filters per your generator’s manual (usually every 100–150 hours of run time)
- Inspecting and replacing air filters when dirty or worn
Inspect Electrical Connections
Corrosion, loose wires, or dirty terminals can lead to electrical failure.
Inspect terminals and wiring every few months
Use dielectric grease to prevent corrosion
Tighten connections as needed, especially after long drives
Keep It Clean and Dry
Moisture and grime can lead to corrosion and short circuits.
Clean your generator compartment periodically
Keep vents clear and ensure proper airflow
Avoid storing your RV under trees that drop sap, pollen, or debris into the unit
By following these maintenance practices, you’ll extend the life of your generator and dramatically reduce the chances of facing a non-starting RV generator on your next adventure. Small, regular checks can save you big repair costs and help ensure that your power is ready when you are.
Final Thoughts – Don’t Let Generator Issues Disrupt Your Travels
Your RV generator plays a critical role in powering your comfort and safety on the road. When it won’t start, it can turn a relaxing getaway into a stressful situation. But with the right approach, most generator problems can be quickly diagnosed and even prevented altogether.
By understanding the common reasons why RV generators fail, following a practical troubleshooting checklist, and keeping up with preventive maintenance, you give yourself the best chance of avoiding power issues in the future. Regularly checking your battery, oil, fuel, and filters can make all the difference.
And when you run into a stubborn issue that just won’t resolve, know that you don’t have to face it alone. Mobile RV repair services like Good Sam RV ProCare are designed to come to you—so you can get back on the road without the hassle of transporting your RV to a shop.
Stay proactive, stay prepared, and you’ll enjoy worry-free travels with a generator that’s ready whenever you need it.
Frequently Asked Questions (FAQs)
					 What’s the first thing I should check when my RV generator won’t start?
				Start by checking the battery voltage, fuel level, and oil level. These are the most common and easily fixable issues. Make sure all cables are connected tightly, and the fuel isn’t old or contaminated.
					 Why does my generator click but not turn over?
				A clicking sound usually points to a weak battery, bad solenoid, or starter motor problem. Double-check the battery charge and connections. If power is flowing but the motor won’t crank, it may be time to call a technician.
					 How often should I run my RV generator to keep it in good condition?
				Run your generator for at least 30 minutes every month under load. This helps keep fuel fresh, lubricates internal parts, and prevents moisture buildup that can lead to corrosion or startup issues.
					 Can I fix an RV generator myself?
				You can often handle basic issues like battery checks, oil refills, and air filter replacements. However, for persistent problems—like fault codes, starter failures, or electrical issues—it’s best to rely on a certified technician.
